Delete an application component snapshot
Deletes a snapshot of an application component. This action is specific to Maxdata template applications and helps manage application snapshots at a more granular level.
HTTP method and endpoint
DELETE /application/applications/{application.uuid}/components/{component.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Delete a snapshot of an application component.
This endpoint is only supported for Maxdata template applications.
Component snapshots are essentially more granular application snapshots. There is no difference beyond the scope of the operation.
Learn more
application.uuid |
string |
path |
True |
Application UUID |
component.uuid |
string |
path |
True |
Application Component UUID |
uuid |
string |
path |
True |
Snapshot UUID |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
