Delete an application component Snapshot copy
Deletes a Snapshot copy of an application component to manage and maintain your application's data state. This operation is specifically for Maxdata template applications, offering a more granular approach to handling application Snapshot copies.
HTTP method and endpoint
DELETE /application/applications/{application.uuid}/components/{component.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Delete a Snapshot copy of an application component.
This endpoint is only supported for Maxdata template applications.
Component Snapshot copies are essentially more granular application Snapshot copies. There is no difference beyond the scope of the operation.
Learn more
application.uuid |
string |
path |
True |
Application UUID |
component.uuid |
string |
path |
True |
Application Component UUID |
uuid |
string |
path |
True |
Snapshot UUID |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
