Delete an application Snapshot copy
Deletes a Snapshot copy of an application. This operation is typically used when you need to remove outdated or unnecessary Snapshot copies to manage storage space efficiently.
HTTP method and endpoint
DELETE /application/applications/{application.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Delete a Snapshot copy of an application
Query examples
Individual Snapshot copies can be destroyed with no query parameters, or a range of Snapshot copies can be destroyed at one time using a query.
The following query deletes all application Snapshot copies created before May 4, 2017
DELETE /application/applications/{application.uuid}/snapshots?create_time=<2017-05-04T00:00:00-05:00
application.uuid |
string |
path |
True |
Application UUID |
uuid |
string |
path |
True |
Snapshot copy UUID |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
