REST API reference
Delete an application Snapshot copy
Deletes a Snapshot copy of an application to remove outdated or unnecessary snapshots as part of your data management strategy.
HTTP method and endpoint
DELETE /application/applications/{application.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Delete a Snapshot copy of an application
Query examples
Individual Snapshot copies can be destroyed with no query parameters, or a range of Snapshot copies can be destroyed at one time using a query.
The following query deletes all application Snapshot copies created before May 4, 2017
DELETE /application/applications/{application.uuid}/snapshots?create_time=<2017-05-04T00:00:00-05:00
application.uuid
string
path
True
Application UUID
uuid
string
path
True
Snapshot copy UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
