Delete an application Snapshot copy
DELETE /application/applications/{application.uuid}/snapshots/{uuid}
Delete a Snapshot copy of an application
Query examples
Individual Snapshot copies can be destroyed with no query parameters, or a range of Snapshot copies can be destroyed at one time using a query.
The following query deletes all application Snapshot copies created before May 4, 2017
DELETE /application/applications/{application.uuid}/snapshots?create_time=<2017-05-04T00:00:00-05:00
return_timeout  |
integer  |
query  |
False  |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202.  |
application.uuid  |
string  |
path  |
True  |
Application UUID  |
uuid  |
string  |
path  |
True  |
Snapshot copy UUID  |
Status: 202, Accepted
| Name | Type | Description |
job  |
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
job_link
_links  |
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
