Delete an application Snapshot copy
Deletes a Snapshot copy of an application. This action is typically used to remove outdated or unnecessary Snapshot copies to free up storage space and manage application data efficiently.
HTTP method and endpoint
DELETE /application/applications/{application.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Delete a Snapshot copy of an application
Query examples
Individual Snapshot copies can be destroyed with no query parameters, or a range of Snapshot copies can be destroyed at one time using a query.
The following query deletes all application Snapshot copies created before May 4, 2017
DELETE /application/applications/{application.uuid}/snapshots?create_time=<2017-05-04T00:00:00-05:00
application.uuid |
string |
path |
True |
Application UUID |
uuid |
string |
path |
True |
Snapshot copy UUID |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
