Delete local users or Active Directory users and groups from a local group and SVM
DELETE /protocols/cifs/local-groups/{svm.uuid}/{local_cifs_group.sid}/members
Introduced In: 9.10
Deletes the local users, Active Directory users and/or Active Directory groups from the specified local group and SVM.
Related ONTAP commands
vserver cifs users-and-groups local-group remove-members
Name | Type | In | Required | Description |
local_cifs_group.sid |
string |
path |
True |
Local group SID |
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
Name | Type | Description |
local_cifs_group |
name |
string |
Local user, Active Directory user, or Active Directory group which is a member of the specified local group. |
records |
array[records] |
An array of local users, Active Directory users, and Active Directory groups specified to add or delete multiple members to or from a local group in a single API call.
Not allowed when the |
svm |
Example request
"local_cifs_group": {
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001"
"name": "string",
"records": [
"name": "string"
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
Status: 200, Ok
Status: Default, Error ontap error response codes | error code | description | | ---------- | ----------- | | 655673 | failed to resolve the member to be deleted from the specified group. | | 655719 | failed to delete a member from the specified group. the error code returned details the failure along with the reason for the failure. take corrective actions as per the specified reason. | | 655742 | records must not be specified when member name is specified. | | 655743 | svm uuid and cifs local group sid are invalid fields for the "records" parameter. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
local_cifs_group
sid |
string |
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method. |
records
name |
string |
href |
string |
_links
self |
svm
_links |
name |
string |
uuid |
string |
local_cifs_group_members
local_cifs_group |
name |
string |
records |
array[records] |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
