REST API reference
Delete local users or Active Directory users and groups from a local group and SVM
Removes local users, Active Directory users, and Active Directory groups from a specified local group and storage virtual machine (SVM). This operation is useful when managing group memberships within your storage environment.
HTTP method and endpoint
DELETE /protocols/cifs/local-groups/{svm.uuid}/{local_cifs_group.sid}/members
Introduced in
ONTAP 9.10
Usage notes
Deletes the local users, Active Directory users and/or Active Directory groups from the specified local group and SVM.
  • vserver cifs users-and-groups local-group remove-members
string
path
True
Local group SID
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
name
string
Local user, Active Directory user, or Active Directory group which is a member of the specified local group.
records
array[records]
An array of local users, Active Directory users, and Active Directory groups specified to add or delete multiple members to or from a local group in a single API call. Not allowed when the name property is used.
Example request
  "name": "string",
  "records": [
      "name": "string"
Status: 200, Ok
Status: Default, Error ontap error response codes | error code | description | | ---------- | ----------- | | 655673     | failed to resolve the member to be deleted from the specified group. | | 655719     | failed to delete a member from the specified group. the error code returned details the failure along with the reason for the failure. take corrective actions as per the specified reason. | | 655742     | records must not be specified when member name is specified. | | 655743     | svm uuid and cifs local group sid are invalid fields for the "records" parameter. |
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
records
name
string
local_cifs_group_members
name
string
records
array[records]
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
