REST API reference
Delete local users or Active Directory users and groups from a local group and SVM
Removes local users, Active Directory users, and Active Directory groups from a specified local group and storage virtual machine (SVM). This operation is useful when managing group memberships within your storage environment.
HTTP method and endpoint
DELETE /protocols/cifs/local-groups/{svm.uuid}/{local_cifs_group.sid}/members
Introduced in
ONTAP 9.10
Usage notes
Deletes the local users, Active Directory users and/or Active Directory groups from the specified local group and SVM.
  • vserver cifs users-and-groups local-group remove-members
string
path
True
Local group SID
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
local_cifs_group
local_cifs_group
name
string
Local user, Active Directory user, or Active Directory group which is a member of the specified local group.
records
array[records]
An array of local users, Active Directory users, and Active Directory groups specified to add or delete multiple members to or from a local group in a single API call. Not allowed when the name property is used.
svm
svm
Example request
  "local_cifs_group": {
    "sid": "S-1-5-21-256008430-3394229847-3930036330-1001"
  "name": "string",
  "records": [
      "name": "string"
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
Status: 200, Ok
Status: Default, Error ontap error response codes | error code | description | | ---------- | ----------- | | 655673     | failed to resolve the member to be deleted from the specified group. | | 655719     | failed to delete a member from the specified group. the error code returned details the failure along with the reason for the failure. take corrective actions as per the specified reason. | | 655742     | records must not be specified when member name is specified. | | 655743     | svm uuid and cifs local group sid are invalid fields for the "records" parameter. |
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
local_cifs_group
sid
string
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method.
records
name
string
string
self
svm
_links
_links
name
string
uuid
string
local_cifs_group_members
local_cifs_group
local_cifs_group
name
string
records
array[records]
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
