REST API reference
Delete a group-to-role mapping entry
Deletes a group-to-role mapping entry to remove the association between a specific group and its assigned role.
HTTP method and endpoint
DELETE /security/group/role-mappings/{group_id}/{ontap_role.name}
Introduced in
ONTAP 9.16
Usage notes
Deletes a group to role mapping entry.
  • security login group role-mapping delete
group_id
integer
path
True
Group ID.
  • format: int64
  • Max value: 4294967295
  • Min value: 1
ontap_role.name
string
path
True
Role name.
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
