Delete a group-to-role mapping entry
DELETE /security/group/role-mappings/{group_id}/{ontap_role.name}
Introduced In: 9.16
Deletes a group to role mapping entry.
Related ONTAP commands
security login group role-mapping delete
group_id |
integer |
path |
True |
Group ID.
ontap_role.name |
string |
path |
True |
Role name. |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
