Retrieve an application snapshot
Retrieves a snapshot of an application component to examine the state of Maxdata template applications at a specific point in time. This helps in managing granular application snapshots effectively.
HTTP method and endpoint
GET /application/applications/{application.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieve a snapshot of an application component.
This endpoint is only supported for Maxdata template applications.
Component snapshots are essentially more granular application snapshots. There is no difference beyond the scope of the operation.
Learn more
application.uuid |
string |
path |
True |
Application UUID |
uuid |
string |
path |
True |
Snapshot UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
application |
comment |
string |
Comment. Valid in POST. |
components |
array[components] |
consistency_type |
string |
Consistency type. This is for categorization purposes only. A snapshot should not be set to 'application consistent' unless the host application is quiesced for the snapshot. Valid in POST. |
create_time |
string |
Creation time |
is_partial |
boolean |
A partial snapshot means that not all volumes in an application component were included in the snapshot. |
name |
string |
The snapshot name. Valid in POST. |
svm |
uuid |
string |
The snapshot UUID. Valid in URL. |
"href": "/api/resourcelink"
"application": {
"name": "string",
"uuid": "string"
"comment": "string",
"components": [
"name": "string",
"uuid": "string"
"consistency_type": "string",
"create_time": "string",
"name": "string",
"svm": {
"name": "string",
"uuid": "string"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
application
_links |
name |
string |
Application name |
uuid |
string |
The application UUID. Valid in URL. |
components
_links |
name |
string |
Component name |
uuid |
string |
Component UUID |
svm
name |
string |
SVM name |
uuid |
string |
SVM UUID |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
