REST API reference
Retrieve cloud targets in the cluster
Retrieves cloud targets in the cluster to access a comprehensive list of all configured cloud storage resources. This operation is typically useful when managing or auditing cloud storage configurations within your cluster environment.
HTTP method and endpoint
GET /cloud/targets
Introduced in
ONTAP 9.6
Usage notes
Retrieves the collection of cloud targets in the cluster.
  • storage aggregate object-store config show
  • snapmirror object-store config show
port
integer
query
False
Filter by port
uuid
string
query
False
Filter by uuid
certificate_validation_enabled
boolean
query
False
Filter by certificate_validation_enabled
ipspace.name
string
query
False
Filter by ipspace.name
ipspace.uuid
string
query
False
Filter by ipspace.uuid
url_style
string
query
False
Filter by url_style
  • Introduced in: 9.8
server_side_encryption
string
query
False
Filter by server_side_encryption
  • Introduced in: 9.7
provider_type
string
query
False
Filter by provider_type
authentication_type
string
query
False
Filter by authentication_type
read_latency_warning_threshold
integer
query
False
Filter by read_latency_warning_threshold
  • Introduced in: 9.15
ssl_enabled
boolean
query
False
Filter by ssl_enabled
azure_account
string
query
False
Filter by azure_account
snapmirror_use
string
query
False
Filter by snapmirror_use
container
string
query
False
Filter by container
cap_url
string
query
False
Filter by cap_url
server
string
query
False
Filter by server
used
integer
query
False
Filter by used
scope
string
query
False
Filter by scope
  • Introduced in: 9.12
use_http_proxy
boolean
query
False
Filter by use_http_proxy
owner
string
query
False
Filter by owner
access_key
string
query
False
Filter by access_key
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
name
string
query
False
Filter by name
cluster.uuid
string
query
False
Filter by cluster.uuid
cluster.name
string
query
False
Filter by cluster.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cloud_target]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "access_key": "string",
      "authentication_type": "string",
      "azure_account": "string",
      "cap_url": "https://123.45.67.89:1234/CAP/api/v1/credentials?agency=myagency&mission=mymission&role=myrole",
      "cluster": {
        "name": "string",
        "uuid": "string"
      "container": "bucket1",
      "ipspace": {
        "name": "Default",
      "name": "string",
      "owner": "string",
      "provider_type": "string",
      "scope": "string",
      "server": "string",
      "server_side_encryption": "string",
      "snapmirror_use": "string",
      "svm": {
        "name": "svm1",
      "url_style": "string",
      "used": 0,
      "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
cluster
name
string
The name of the cluster that owns the cloud target. For POST, this accepts the name of the peer cluster only if the cluster is in switchover state.
uuid
string
The UUID of the cluster that owns the cloud target. For POST, this accepts the UUID of the peer cluster only if the cluster is in switchover state.
ipspace
IPspace to use in order to reach the cloud target.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
svm
This field is only applicable when used for SnapMirror and FabricLink. For POST and PATCH, SVM information is required for SnapMirror and FabricLink targets when the scope is svm and is not allowed for FabricPool targets. For GET, this field is not set if the scope of the cloud target is "cluster".
_links
_links
name
string
uuid
string
cloud_target
_links
_links
access_key
string
Access key ID for AWS_S3 and other S3 compatible provider types.
authentication_type
string
Authentication used to access the target. SnapMirror does not yet support CAP. Required in POST.
azure_account
string
Azure account
cap_url
string
This parameter is available only when auth-type is CAP. It specifies a full URL of the request to a CAP server for retrieving temporary credentials (access-key, secret-password, and session token) for accessing the object store.
boolean
Is SSL/TLS certificate validation enabled? The default value is true. This can only be modified for SGWS, IBM_COS, and ONTAP_S3 provider types.
  • Introduced in: 9.6
  • x-nullable: true
cluster
cluster
container
string
Data bucket/container name. For FabricLink, a wildcard character "*" can also be specified to indicate that all the buckets in an SVM can use the same target information. However, for containers other than ONTAP, an exact name should be specified.
  • example: bucket1
  • readCreate: 1
  • x-nullable: true
ipspace
ipspace
name
string
Cloud target name
owner
string
Owner of the target. Allowed values are FabricPool, SnapMirror or S3_SnapMirror. A target can be used by only one feature.
port
integer
Port number of the object store that ONTAP uses when establishing a connection. Required in POST.
  • x-nullable: true
provider_type
string
Type of cloud provider. Allowed values depend on owner type. For FabricPool, AliCloud, AWS_S3, Azure_Cloud, GoogleCloud, IBM_COS, SGWS, and ONTAP_S3 are allowed. For SnapMirror, the valid values are AWS_S3 or SGWS. For FabricLink, AWS_S3, SGWS, S3_Compatible, S3EMU, LOOPBACK and ONTAP_S3 are allowed.
  • readCreate: 1
  • x-nullable: true
integer
The warning threshold for read latency that is used to determine when an alert ems for a read operation from an object store should be issued.
scope
string
If the cloud target is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster.
server
string
Fully qualified domain name of the object store server. Required on POST. For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3-.amazonaws.com, for example, s3-us-west-2.amazonaws.com. The region of the server and the bucket must match. For Azure, if the server is a "blob.core.windows.net" or a "blob.core.usgovcloudapi.net", then a value of azure-account followed by a period is added in front of the server.
string
Encryption of data at rest by the object store server for AWS_S3 and other S3 compatible provider types. In most cases it is best not to change default value of "sse_s3" for object store servers which support SSE-S3 encryption. The encryption is in addition to any encryption done by ONTAP at a volume or at an aggregate level. Note that changing this option does not change encryption of data which already exist in the object store.
  • enum: ["none", "sse_s3", "sse_kms", "dsse_kms"]
  • x-nullable: true
snapmirror_use
string
Use of the cloud target by SnapMirror.
ssl_enabled
boolean
SSL/HTTPS enabled or not
svm
svm
url_style
string
URL style used to access S3 bucket.
use_http_proxy
boolean
Use HTTP proxy when connecting to the object store.
used
integer
The amount of cloud space used by all the aggregates attached to the target, in bytes. This field is only populated for FabricPool targets. The value is recalculated once every 5 minutes.
uuid
string
Cloud target UUID
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
