REST API reference
Retrieve cloud targets in the cluster
Retrieves the collection of cloud targets in the cluster to view available configurations for object storage connections.
HTTP method and endpoint
GET /cloud/targets
Introduced in
ONTAP 9.6
  • storage aggregate object-store config show
cap_url
string
query
False
Filter by cap_url
cluster.uuid
string
query
False
Filter by cluster.uuid
  • Introduced in: 9.7
cluster.name
string
query
False
Filter by cluster.name
used
integer
query
False
Filter by used
certificate_validation_enabled
boolean
query
False
Filter by certificate_validation_enabled
uuid
string
query
False
Filter by uuid
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
ssl_enabled
boolean
query
False
Filter by ssl_enabled
server
string
query
False
Filter by server
snapmirror_use
string
query
False
Filter by snapmirror_use
owner
string
query
False
Filter by owner
access_key
string
query
False
Filter by access_key
container
string
query
False
Filter by container
provider_type
string
query
False
Filter by provider_type
azure_account
string
query
False
Filter by azure_account
url_style
string
query
False
Filter by url_style
  • Introduced in: 9.8
port
integer
query
False
Filter by port
ipspace.uuid
string
query
False
Filter by ipspace.uuid
ipspace.name
string
query
False
Filter by ipspace.name
use_http_proxy
boolean
query
False
Filter by use_http_proxy
authentication_type
string
query
False
Filter by authentication_type
name
string
query
False
Filter by name
server_side_encryption
string
query
False
Filter by server_side_encryption
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cloud_target]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "access_key": "string",
      "authentication_type": "string",
      "azure_account": "string",
      "cap_url": "https://123.45.67.89:1234/CAP/api/v1/credentials?agency=myagency&mission=mymission&role=myrole",
      "cluster": {
        "name": "string",
        "uuid": "string"
      "container": "bucket1",
      "ipspace": {
        "name": "exchange",
      "name": "string",
      "owner": "string",
      "provider_type": "string",
      "server": "string",
      "server_side_encryption": "string",
      "snapmirror_use": "string",
      "svm": {
        "name": "svm1",
      "url_style": "string",
      "used": 0,
      "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
cluster
name
string
The name of the cluster that owns the cloud target. For POST, this accepts the name of the peer cluster only if the cluster is in switchover state.
uuid
string
The UUID of the cluster that owns the cloud target. For POST, this accepts the UUID of the peer cluster only if the cluster is in switchover state.
ipspace
IPspace to use in order to reach the cloud target.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
svm
This field is only applicable when used for SnapMirror. For POST and PATCH, SVM information is required for SnapMirror targets and not allowed for FabricPool targets.
_links
_links
name
string
The name of the SVM.
uuid
string
cloud_target
_links
_links
access_key
string
Access key ID for AWS_S3 and other S3 compatible provider types.
authentication_type
string
Authentication used to access the target. SnapMirror does not yet support CAP. Required in POST.
azure_account
string
Azure account
cap_url
string
This parameter is available only when auth-type is CAP. It specifies a full URL of the request to a CAP server for retrieving temporary credentials (access-key, secret-pasword, and session token) for accessing the object store.
boolean
Is SSL/TLS certificate validation enabled? The default value is true. This can only be modified for SGWS, IBM_COS, and ONTAP_S3 provider types.
  • Introduced in: 9.6
cluster
cluster
container
string
Data bucket/container name
ipspace
ipspace
name
string
Cloud target name
owner
string
Owner of the target. Allowed values are FabricPool or SnapMirror. A target can be used by only one feature.
port
integer
Port number of the object store that ONTAP uses when establishing a connection. Required in POST.
provider_type
string
Type of cloud provider. Allowed values depend on owner type. For FabricPool, AliCloud, AWS_S3, Azure_Cloud, GoggleCloud, IBM_COS, SGWS, and ONTAP_S3 are allowed. For SnapMirror, the valid values are AWS_S3 or SGWS.
  • readCreate: 1
server
string
Fully qualified domain name of the object store server. Required on POST. For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3-.amazonaws.com, for example, s3-us-west-2.amazonaws.com. The region of the server and the bucket must match. For Azure, if the server is a "blob.core.windows.net" or a "blob.core.usgovcloudapi.net", then a value of azure-account followed by a period is added in front of the server.
string
Encryption of data at rest by the object store server for AWS_S3 and other S3 compatible provider types. This is an advanced property. In most cases it is best not to change default value of "sse_s3" for object store servers which support SSE-S3 encryption. The encryption is in addition to any encryption done by ONTAP at a volume or at an aggregate level. Note that changing this option does not change encryption of data which already exist in the object store.
  • enum: ["none", "sse_s3"]
snapmirror_use
string
Use of the cloud target by SnapMirror.
ssl_enabled
boolean
SSL/HTTPS enabled or not
svm
svm
url_style
string
URL style used to access S3 bucket.
use_http_proxy
boolean
Use HTTP proxy when connecting to the object store.
used
integer
The amount of cloud space used by all the aggregates attached to the target, in bytes. This field is only populated for FabricPool targets. The value is recalculated once every 5 minutes.
uuid
string
Cloud target UUID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
