REST API reference
Retrieve capacity pool information
Accesses detailed information about the capacity pool, which helps you manage and monitor storage resources effectively.
HTTP method and endpoint
GET /cluster/licensing/capacity-pools/{serial_number}
Introduced in
ONTAP 9.8
Usage notes
Retrieves information about the capacity pool.
  • system license show-status
serial_number
string
path
True
Serial number of the capacity pool license.
license_manager.uuid
string
query
False
Filter by license_manager.uuid
nodes.used_size
integer
query
False
Filter by nodes.used_size
nodes.node.uuid
string
query
False
Filter by nodes.node.uuid
nodes.node.name
string
query
False
Filter by nodes.node.name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
license_manager
license_manager
License manager instance where this capacity pool license in installed.
nodes
array[nodes]
Nodes in the cluster associated with this capacity pool.
serial_number
string
      "href": "/api/resourcelink"
  "license_manager": {
    "uuid": "4ea7a442-86d1-11e0-ae1c-112233445566"
  "nodes": [
      "node": {
        "name": "node1",
      "used_size": 0
  "serial_number": 390000100
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
license_manager
_links
self_link
uuid
string
self
node_reference
_links
_links
name
string
uuid
string
nodes
Information on a node from the capacity licensing perspective.
node
node_reference
used_size
integer
Capacity, in bytes, that is currently used by the node.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
