REST API reference
Retrieve capacity pool information
Accesses detailed capacity pool information to understand resource allocation and usage in your storage environment. This helps in optimizing storage management and planning.
HTTP method and endpoint
GET /cluster/licensing/capacity-pools/{serial_number}
Introduced in
ONTAP 9.8
Usage notes
Retrieves information about the capacity pool.
  • system license show-status
serial_number
string
path
True
Serial number of the capacity pool license.
nodes.used_size
integer
query
False
Filter by nodes.used_size
nodes.node.name
string
query
False
Filter by nodes.node.name
nodes.node.uuid
string
query
False
Filter by nodes.node.uuid
license_manager.uuid
string
query
False
Filter by license_manager.uuid
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
license_manager
license_manager
License manager instance where this capacity pool license in installed.
nodes
array[nodes]
Nodes in the cluster associated with this capacity pool.
serial_number
string
      "href": "/api/resourcelink"
  "license_manager": {
    "uuid": "4ea7a442-86d1-11e0-ae1c-112233445566"
  "nodes": [
      "node": {
        "name": "node1",
      "used_size": 0
  "serial_number": 390000100
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
license_manager
_links
self_link
uuid
string
self
node_reference
_links
_links
name
string
uuid
string
nodes
Information on a node from the capacity licensing perspective.
node
node_reference
used_size
integer
Capacity, in bytes, that is currently used by the node.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
