Retrieve applied central access policies for an SVM
GET /protocols/cifs/group-policies/{svm.uuid}/central-access-policies
Introduced In: 9.12
Retrieves applied central access policies for specified SVM.
Related ONTAP commands
vserver cifs group-policy central-access-policy show-applied
svm.name  |
string  |
query  |
False  |
Filter by svm.name  |
name  |
string  |
query  |
False  |
Filter by name
create_time  |
string  |
query  |
False  |
Filter by create_time  |
sid  |
string  |
query  |
False  |
Filter by sid  |
update_time  |
string  |
query  |
False  |
Filter by update_time  |
member_rules  |
string  |
query  |
False  |
Filter by member_rules  |
description  |
string  |
query  |
False  |
Filter by description  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of central access policies.  |
records  |
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "create_time": "2018-01-01 11:00:00 -0500",
      "description": "policy #1",
      "member_rules": [
        "r1",
        "r2"
      "name": "p1",
      "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
      "svm": {
        "name": "svm1",
      "update_time": "2018-01-01 11:00:00 -0500"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
svm
Will not be populated for objects that are yet to be applied.
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
group_policy_object_central_access_policy
create_time  |
string  |
Policy creation timestamp.  |
description  |
string  |
Description about the policy.  |
member_rules  |
array[string]  |
Names of all central access rules applied to members.  |
name  |
string  |
sid  |
string  |
Security ID, unique identifier of the central policy.  |
svm  |
Will not be populated for objects that are yet to be applied.  |
update_time  |
string  |
Last policy modification timestamp.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
