Retrieve applied central access policies for an SVM
GET /protocols/cifs/group-policies/{svm.uuid}/central-access-policies
Introduced In: 9.12
Retrieves applied central access policies for specified SVM.
Related ONTAP commands
vserver cifs group-policy central-access-policy show-applied
description |
string |
query |
False |
Filter by description |
svm.name |
string |
query |
False |
Filter by svm.name |
update_time |
string |
query |
False |
Filter by update_time |
create_time |
string |
query |
False |
Filter by create_time |
member_rules |
string |
query |
False |
Filter by member_rules |
sid |
string |
query |
False |
Filter by sid |
name |
string |
query |
False |
Filter by name
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of central access policies. |
records |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"create_time": "2018-01-01 11:00:00 -0500",
"description": "policy #1",
"member_rules": [
"r1",
"r2"
"name": "p1",
"sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
"svm": {
"name": "svm1",
"update_time": "2018-01-01 11:00:00 -0500"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
Will not be populated for objects that are yet to be applied.
_links |
name |
string |
uuid |
string |
group_policy_object_central_access_policy
create_time |
string |
Policy creation timestamp. |
description |
string |
Description about the policy. |
member_rules |
array[string] |
Names of all central access rules applied to members. |
name |
string |
sid |
string |
Security ID, unique identifier of the central policy. |
svm |
Will not be populated for objects that are yet to be applied. |
update_time |
string |
Last policy modification timestamp. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
