Retrieve SMB session information for an SMB connection in an SVM node
Retrieves specific SMB session information from a connection in an SVM node, helping you monitor or troubleshoot SMB activity within your storage environment.
HTTP method and endpoint
GET /protocols/cifs/sessions/{node.uuid}/{svm.uuid}/{identifier}/{connection_id}
Introduced in
ONTAP 9.8
Usage notes
Retrieves specific SMB session information for a specific SMB connection in a node on an SVM.
Learn more
node.uuid |
string |
path |
True |
Node UUID. |
identifier |
integer |
path |
True |
Unique identifier for the SMB session. |
connection_id |
integer |
path |
True |
Unique identifier for the SMB connection. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
authentication |
string |
SMB authentication over which the client accesses the share. The following values are supported:
client_ip |
string |
Specifies IP address of the client. |
connected_duration |
string |
Specifies an ISO-8601 format of date and time used to retrieve the connected time duration in hours, minutes, and seconds format. |
connection_count |
integer |
A counter used to track requests that are sent to the volumes to the node. |
connection_id |
integer |
A unique 32-bit unsigned number used to represent each SMB session's connection ID. |
continuous_availability |
string |
The level of continuous availability protection provided to the SMB sessions and/or files.
identifier |
integer |
A unique 64-bit unsigned number used to represent each SMB session's identifier. |
idle_duration |
string |
Specifies an ISO-8601 format of date and time used to retrieve the idle time duration in hours, minutes, and seconds format. |
large_mtu |
boolean |
Specifies whether the large MTU is enabled or not for an SMB session. |
mapped_unix_user |
string |
Indicated that a mapped UNIX user has logged in. |
node |
open_files |
integer |
Number of files the SMB session has opened. |
open_other |
integer |
Number of other files the SMB session has opened. |
open_shares |
integer |
Number of shares the SMB session has opened. |
protocol |
string |
The SMB protocol version over which the client accesses the volumes. The following values are supported:
server_ip |
string |
Specifies the IP address of the SVM. |
smb_encryption |
string |
Indicates an SMB encryption state. The following values are supported:
smb_signing |
boolean |
Specifies whether or not SMB signing is enabled. |
svm |
user |
string |
Indicates that a Windows user has logged in. |
volumes |
array[volumes] |
A group of volumes, the client is accessing. |
"href": "/api/resourcelink"
"authentication": "ntlmv2",
"client_ip": "10.74.7.182",
"connected_duration": "P4DT84H30M5S",
"connection_count": 0,
"connection_id": 22802,
"continuous_availability": "unavailable",
"identifier": 4622663542519103507,
"idle_duration": "P4DT84H30M5S",
"large_mtu": true,
"mapped_unix_user": "root",
"node": {
"name": "node1",
"open_files": 0,
"open_other": 0,
"open_shares": 0,
"protocol": "smb3_1",
"server_ip": "10.140.78.248",
"smb_encryption": "unencrypted",
"smb_signing": "",
"svm": {
"name": "svm1",
"user": "NBCIFSQA2\\administrator",
"volumes": [
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
node
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
uuid |
string |
volumes
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
