REST API reference
Retrieve the SMB session information for an SMB connection in an SVM node
Retrieves specific SMB session information from a connection in an SVM node, helping you monitor or troubleshoot SMB activity within your storage environment.
HTTP method and endpoint
GET /protocols/cifs/sessions/{node.uuid}/{svm.uuid}/{identifier}/{connection_id}
Introduced in
ONTAP 9.8
Usage notes
Retrieves specific SMB session information for a specific SMB connection in a node on an SVM.
node.uuid
string
path
True
Node UUID.
identifier
integer
path
True
Unique identifier for the SMB session.
connection_id
integer
path
True
Unique identifier for the SMB connection.
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
authentication
string
SMB authentication over which the client accesses the share. The following values are supported:
  • none - No authentication
  • ntlmv1 - Ntlm version 1 mechanism
  • ntlmv2 - Ntlm version 2 mechanism
  • kerberos - Kerberos authentication
  • anonymous - Anonymous mechanism
client_ip
string
Specifies IP address of the client.
connected_duration
string
Specifies an ISO-8601 format of date and time used to retrieve the connected time duration in hours, minutes, and seconds format.
connection_count
integer
A counter used to track requests that are sent to the volumes to the node.
connection_id
integer
A unique 32-bit unsigned number used to represent each SMB session's connection ID.
continuous_availability
string
The level of continuous availabilty protection provided to the SMB sessions and/or files.
  • unavailable - Open file is not continuously available. For sessions, it contains one or more open files but none of them are continuously available.
  • available - open file is continuously available. For sessions, it contains one or more open files and all of them are continuously available.
  • partial - Sessions only. Contains at least one continuously available open file with other files open but not continuously available.
identifier
integer
A unique 64-bit unsigned number used to represent each SMB session's identifier.
idle_duration
string
Specifies an ISO-8601 format of date and time used to retrieve the idle time duration in hours, minutes, and seconds format.
large_mtu
boolean
Specifies whether the large MTU is enabled or not for an SMB session.
mapped_unix_user
string
Indicated that a mapped UNIX user has logged in.
node
node
open_files
integer
Number of files the SMB session has opened.
open_other
integer
Number of other files the SMB session has opened.
open_shares
integer
Number of shares the SMB session has opened.
protocol
string
The SMB protocol version over which the client accesses the volumes. The following values are supported:
  • smb1 - SMB version 1
  • smb2 - SMB version 2
  • smb2_1 - SMB version 2 minor version 1
  • smb3 - SMB version 3
  • smb3_1 - SMB version 3 minor version 1
server_ip
string
Specifies the IP address of the SVM.
smb_encryption
string
Indicates an SMB encryption state. The following values are supported:
  • unencrypted - SMB session is not encrypted
  • encrypted - SMB session is fully encrypted. SVM level encryption is enabled and encryption occurs for the entire session.
  • partially_encrypted - SMB session is partially encrypted. Share level encryption is enabled and encryption is initiated when the tree-connect occurs.
smb_signing
boolean
Specifies whether or not SMB signing is enabled.
svm
svm
user
string
Indicates that a Windows user has logged in.
volumes
array[volumes]
A group of volumes, the client is accessing.
      "href": "/api/resourcelink"
  "authentication": "ntlmv2",
  "client_ip": "10.74.7.182",
  "connected_duration": "P4DT84H30M5S",
  "connection_count": 0,
  "connection_id": 22802,
  "continuous_availability": "unavailable",
  "identifier": 4622663542519103507,
  "idle_duration": "P4DT84H30M5S",
  "large_mtu": true,
  "mapped_unix_user": "root",
  "node": {
    "name": "node1",
  "open_files": 0,
  "open_other": 0,
  "open_shares": 0,
  "protocol": "smb3_1",
  "server_ip": "10.140.78.248",
  "smb_encryption": "unencrypted",
  "smb_signing": "",
  "svm": {
    "name": "svm1",
  "user": "NBCIFSQA2\\administrator",
  "volumes": [
      "name": "volume1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
node
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volumes
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.8
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
