REST API reference
Retrieve the FPolicy engine configuration for all engines of an SVM
Retrieves the FPolicy engine configurations for all engines associated with a specific SVM. This information helps you understand the cluster-level FPolicy engines that serve as templates across the SVMs within the cluster.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/engines
Introduced in
ONTAP 9.6
Usage notes
Retrieves FPolicy engine configurations of all the engines for a specified SVM. ONTAP allows creation of cluster-level FPolicy engines that act as a template for all the SVMs belonging to the cluster. These cluster-level FPolicy engines are also retrieved for the specified SVM.
  • fpolicy policy external-engine show
server_progress_timeout
string
query
False
Filter by server_progress_timeout
  • Introduced in: 9.11
port
integer
query
False
Filter by port
type
string
query
False
Filter by type
format
string
query
False
Filter by format
resiliency.retention_duration
string
query
False
Filter by resiliency.retention_duration
resiliency.enabled
boolean
query
False
Filter by resiliency.enabled
resiliency.directory_path
string
query
False
Filter by resiliency.directory_path
max_server_requests
integer
query
False
Filter by max_server_requests
  • Max value: 10000
  • Min value: 1
primary_servers
string
query
False
Filter by primary_servers
keep_alive_interval
string
query
False
Filter by keep_alive_interval
  • Introduced in: 9.13
ssl_option
string
query
False
Filter by ssl_option
certificate.ca
string
query
False
Filter by certificate.ca
certificate.name
string
query
False
Filter by certificate.name
certificate.serial_number
string
query
False
Filter by certificate.serial_number
name
string
query
False
Filter by name
buffer_size.send_buffer
integer
query
False
Filter by buffer_size.send_buffer
  • Max value: 7895160
  • Min value: 0
buffer_size.recv_buffer
integer
query
False
Filter by buffer_size.recv_buffer
  • Min value: 0
status_request_interval
string
query
False
Filter by status_request_interval
secondary_servers
string
query
False
Filter by secondary_servers
request_abort_timeout
string
query
False
Filter by request_abort_timeout
request_cancel_timeout
string
query
False
Filter by request_cancel_timeout
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[fpolicy_engine]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "certificate": {
        "ca": "TASample1",
        "name": "Sample1-FPolicy-Client",
        "serial_number": "8DDE112A114D1FBC"
      "format": "string",
      "keep_alive_interval": "PT2M",
      "max_server_requests": 500,
      "name": "fp_ex_eng",
      "port": 9876,
      "primary_servers": [
        "10.132.145.20",
        "10.140.101.109"
      "request_abort_timeout": "PT40S",
      "request_cancel_timeout": "PT20S",
      "resiliency": {
        "directory_path": "/dir1",
        "retention_duration": "PT3M"
      "secondary_servers": [
        "10.132.145.20",
        "10.132.145.21"
      "server_progress_timeout": "PT1M",
      "ssl_option": "string",
      "status_request_interval": "PT10S",
      "svm": {
        "uuid": "string"
      "type": "string"
Status: Default,
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
buffer_size
Specifies the send and receive buffer size of the connected socket for the FPolicy server.
recv_buffer
integer
Specifies the receive buffer size of the connected socket for the FPolicy server. Default value is 256KB.
send_buffer
integer
Specifies the send buffer size of the connected socket for the FPolicy server. Default value 1MB.
certificate
Provides details about certificate used to authenticate the FPolicy server.
ca
string
Specifies the certificate authority (CA) name of the certificate used for authentication if SSL authentication between the SVM and the FPolicy server is configured.
name
string
Specifies the certificate name as a fully qualified domain name (FQDN) or custom common name. The certificate is used if SSL authentication between the SVM and the FPolicy server is configured.
serial_number
string
Specifies the serial number of the certificate used for authentication if SSL authentication between the SVM and the FPolicy server is configured.
resiliency
If all primary and secondary servers are down, or if no response is received from the FPolicy servers, file access events are stored inside the storage controller under the specified resiliency-directory-path.
directory_path
string
Specifies the directory path under the SVM namespace, where notifications are stored in the files whenever a network outage happens.
enabled
boolean
Specifies whether the resiliency feature is enabled or not. Default is false.
retention_duration
string
Specifies the ISO-8601 duration, for which the notifications are written to files inside the storage controller during a network outage. The value for this field must be between 0 and 600 seconds. Default is 180 seconds.
svm
uuid
string
SVM UUID
fpolicy_engine
Defines how ONTAP makes and manages connections to external FPolicy servers.
buffer_size
buffer_size
certificate
certificate
format
string
The format for the notification messages sent to the FPolicy servers. The possible values are:
  • xml - Notifications sent to the FPolicy server will be formatted using the XML schema.
  • protobuf - Notifications sent to the FPolicy server will be formatted using Protobuf schema, which is a binary form.
keep_alive_interval
string
Specifies the ISO-8601 interval time for a storage appliance to send Keep Alive message to an FPolicy server. The allowed range is between 10 to 600 seconds.
max_server_requests
integer
Specifies the maximum number of outstanding requests for the FPolicy server. It is used to specify maximum outstanding requests that will be queued up for the FPolicy server. The value for this field must be between 1 and 10000. The default values are 500, 1000 or 2000 for Low-end(<64 GB memory), Mid-end(>=64 GB memory) and High-end(>=128 GB memory) Platforms respectively.
name
string
Specifies the name to assign to the external server configuration.
port
integer
Port number of the FPolicy server application.
primary_servers
array[string]
string
Specifies the ISO-8601 timeout duration for a screen request to be aborted by a storage appliance. The allowed range is between 0 to 200 seconds.
string
Specifies the ISO-8601 timeout duration for a screen request to be processed by an FPolicy server. The allowed range is between 0 to 100 seconds.
resiliency
resiliency
secondary_servers
array[string]
string
Specifies the ISO-8601 timeout duration in which a throttled FPolicy server must complete at least one screen request. If no request is processed within the timeout, connection to the FPolicy server is terminated. The allowed range is between 0 to 100 seconds.
ssl_option
string
Specifies the SSL option for external communication with the FPolicy server. Possible values include the following:
  • no_auth When set to "no_auth", no authentication takes place.
  • server_auth When set to "server_auth", only the FPolicy server is authenticated by the SVM. With this option, before creating the FPolicy external engine, the administrator must install the public certificate of the certificate authority (CA) that signed the FPolicy server certificate.
  • mutual_auth When set to "mutual_auth", mutual authentication takes place between the SVM and the FPolicy server. This means authentication of the FPolicy server by the SVM along with authentication of the SVM by the FPolicy server. With this option, before creating the FPolicy external engine, the administrator must install the public certificate of the certificate authority (CA) that signed the FPolicy server certificate along with the public certificate and key file for authentication of the SVM.
string
Specifies the ISO-8601 interval time for a storage appliance to query a status request from an FPolicy server. The allowed range is between 0 to 50 seconds.
svm
svm
type
string
The notification mode determines what ONTAP does after sending notifications to FPolicy servers. The possible values are:
  • synchronous - After sending a notification, wait for a response from the FPolicy server.
  • asynchronous - After sending a notification, file request processing continues.
    • Default value: 1
    • enum: ["synchronous", "asynchronous"]
    • Introduced in: 9.6
    • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
