Retrieve the FPolicy engine configuration for all engines of an SVM
Retrieves the FPolicy engine configuration for all engines associated with a specified SVM. This includes cluster-level FPolicy engines that serve as templates for SVMs within the cluster.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/engines
Introduced in
ONTAP 9.6
Usage notes
Retrieves FPolicy engine configurations of all the engines for a specified SVM. ONTAP allows creation of cluster-level FPolicy engines that act as a template for all the SVMs belonging to the cluster. These cluster-level FPolicy engines are also retrieved for the specified SVM.
Related ONTAP commands
fpolicy policy external-engine show
Learn more
secondary_servers |
string |
query |
False |
Filter by secondary_servers |
type |
string |
query |
False |
Filter by type |
primary_servers |
string |
query |
False |
Filter by primary_servers |
port |
integer |
query |
False |
Filter by port |
name |
string |
query |
False |
Filter by name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[fpolicy_engine] |
"next": {
"href": "/api/resourcelink"
"records": [
"name": "fp_ex_eng",
"port": "9876",
"primary_servers": [
"10.132.145.20",
"10.140.101.109"
"secondary_servers": [
"10.132.145.20",
"10.132.145.21"
"type": "string"
Status: Default,
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
fpolicy_engine
The engine defines how ONTAP makes and manages connections to external FPolicy servers.
name |
string |
Specifies the name to assign to the external server configuration. |
port |
integer |
Port number of the FPolicy server application. |
primary_servers |
array[string] |
secondary_servers |
array[string] |
type |
string |
The notification mode determines what ONTAP does after sending notifications to FPolicy servers. The possible values are:
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
