Retrieve NVMe subsystem maps
Retrieves NVMe subsystem maps to access details about the mappings between subsystems and namespaces. This operation is useful for understanding the configuration and relationships within your NVMe storage setup.
HTTP method and endpoint
GET /protocols/nvme/subsystem-maps
Introduced in
ONTAP 9.6
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
anagrpid
Related ONTAP commands
vserver nvme subsystem map show
Learn more
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
subsystem.name |
string |
query |
False |
Filter by subsystem.name
subsystem.uuid |
string |
query |
False |
Filter by subsystem.uuid |
nsid |
string |
query |
False |
Filter by nsid |
namespace.uuid |
string |
query |
False |
Filter by namespace.uuid |
namespace.node.uuid |
string |
query |
False |
Filter by namespace.node.uuid |
namespace.node.name |
string |
query |
False |
Filter by namespace.node.name |
namespace.name |
string |
query |
False |
Filter by namespace.name |
anagrpid |
string |
query |
False |
Filter by anagrpid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[nvme_subsystem_map] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"anagrpid": "00103050h",
"namespace": {
"name": "/vol/vol1/namespace1",
"node": {
"name": "node1",
"nsid": "00000001h",
"subsystem": {
"name": "subsystem1",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
namespace
The NVMe namespace to which the NVMe subsystem is mapped. Required in POST by supplying either the UUID, name, or both.
_links |
name |
string |
The name of the NVMe namespace. Valid in POST. An NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume. NVMe namespace names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional. |
node |
uuid |
string |
The unique identifier of the NVMe namespace. Valid in POST. |
subsystem
The NVMe subsystem to which the NVMe namespace is mapped. Required in POST by supplying either subsystem.uuid, subsystem.name or both.
_links |
name |
string |
The name of the NVMe subsystem. |
uuid |
string |
The unique identifier of the NVMe subsystem. |
svm
_links |
name |
string |
uuid |
string |
nvme_subsystem_map
An NVMe subsystem map is an association of an NVMe namespace with an NVMe subsystem. When an NVMe namespace is mapped to an NVMe subsystem, the NVMe subsystem's hosts are granted access to the NVMe namespace. The relationship between an NVMe subsystem and an NVMe namespace is one subsystem to many namespaces.
_links |
anagrpid |
string |
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace. The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h". There is an added computational cost to retrieving this property's value. It is not populated for a GET request unless it is explicitly requested using the |
namespace |
The NVMe namespace to which the NVMe subsystem is mapped. Required in POST by supplying either the UUID, name, or both. |
nsid |
string |
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace. The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h". |
subsystem |
The NVMe subsystem to which the NVMe namespace is mapped. Required in POST by supplying either |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
