REST API reference
Retrieve NVMe subsystem maps
GET /protocols/nvme/subsystem-maps
Introduced In: 9.6
Retrieves NVMe subsystem maps.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • anagrpid
  • vserver nvme subsystem map show
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
subsystem.uuid
string
query
False
Filter by subsystem.uuid
subsystem.name
string
query
False
Filter by subsystem.name
  • maxLength: 64
  • minLength: 1
nsid
string
query
False
Filter by nsid
namespace.node.name
string
query
False
Filter by namespace.node.name
namespace.node.uuid
string
query
False
Filter by namespace.node.uuid
namespace.uuid
string
query
False
Filter by namespace.uuid
namespace.name
string
query
False
Filter by namespace.name
anagrpid
string
query
False
Filter by anagrpid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[nvme_subsystem_map]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "anagrpid": "00103050h",
      "namespace": {
        "name": "/vol/vol1/namespace1",
        "node": {
          "name": "node1",
      "nsid": "00000001h",
      "subsystem": {
        "name": "subsystem1",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
namespace
The NVMe namespace to which the NVMe subsystem is mapped. Required in POST by supplying either the UUID, name, or both.
_links
_links
name
string
The name of the NVMe namespace. Valid in POST. An NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume.
NVMe namespace names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional.
node
node
uuid
string
The unique identifier of the NVMe namespace. Valid in POST.
subsystem
The NVMe subsystem to which the NVMe namespace is mapped. Required in POST by supplying either subsystem.uuid, subsystem.name or both.
_links
_links
name
string
The name of the NVMe subsystem.
uuid
string
The unique identifier of the NVMe subsystem.
svm
_links
_links
name
string
uuid
string
nvme_subsystem_map
An NVMe subsystem map is an association of an NVMe namespace with an NVMe subsystem. When an NVMe namespace is mapped to an NVMe subsystem, the NVMe subsystem's hosts are granted access to the NVMe namespace. The relationship between an NVMe subsystem and an NVMe namespace is one subsystem to many namespaces.
_links
_links
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
There is an added computational cost to retrieving this property's value. It is not populated for a GET request unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
namespace
namespace
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
subsystem
subsystem
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
