REST API reference
Retrieve a nested initiator group of an initiator group
Retrieves a nested initiator group that is a direct child of an existing initiator group, giving you insight into its immediate hierarchy. This helps manage your storage network by understanding the direct relationships between initiator groups.
HTTP method and endpoint
GET /protocols/san/igroups/{igroup.uuid}/igroups/{uuid}
Introduced in
ONTAP 9.9
Usage notes
Retrieves a nested initiator group of an initiator group.
This API only reports the nested initiator groups that are direct children of the initiator group. Further nested initiator groups are reported by their direct parent initiator group.
  • lun igroup show
igroup.uuid
string
path
True
The unique identifier of the parent initiator group.
uuid
string
path
True
The unique identifier of the nested initiator group.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
igroup
igroup
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
      "href": "/api/resourcelink"
  "igroup": {
  "name": "igroup1",
Status: Default
ONTAP Error Response Codes
Error Code Description
4
The nested initiator group is not a member of the initiator group.
5374852
The parent initiator group specified in the URI does not exist.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
igroup
_links
_links
uuid
string
records
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
