Retrieve a nested initiator group of an initiator group
GET /protocols/san/igroups/{igroup.uuid}/igroups/{uuid}
Introduced In: 9.9
Retrieves a nested initiator group of an initiator group.
This API only reports the nested initiator groups that are direct children of the initiator group. Further nested initiator groups are reported by their direct parent initiator group.
Related ONTAP commands
lun igroup show
Learn more
igroup.uuid |
string |
path |
True |
The unique identifier of the parent initiator group. |
uuid |
string |
path |
True |
The unique identifier of the nested initiator group. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
igroup |
name |
string |
The name of the initiator group. |
uuid |
string |
The unique identifier of the initiator group. |
"href": "/api/resourcelink"
"igroup": {
"name": "igroup1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4 |
The nested initiator group is not a member of the initiator group. |
5374852 |
The parent initiator group specified in the URI does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
igroup
_links |
uuid |
string |
records
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
