Retrieve the resources for a tag
GET /resource-tags/{resource_tag.value}/resources
Introduced In: 9.13
Retrieves the resources for a specific tag
resource_tag.value |
string |
path |
True |
value |
string |
query |
False |
Filter by value
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
label |
string |
query |
False |
Filter by label |
href |
string |
query |
False |
Filter by href
return_timeout |
integer |
query |
False |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
return_records |
boolean |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[resource_tag_resource] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"href": "string",
"label": "volume",
"svm": {
"name": "svm1",
"value": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
If the tagged resource belongs to an SVM, this property will be set. If the resource does not belong to an SVM (i.e. it belongs to the cluster as a whole), then this property will be empty and unreturned.
_links |
name |
string |
uuid |
string |
This object provides a pointer to the tagged resource in the API. Details about the tagged object are available by querying the address of the href property.
href |
string |
This property provides the address in the API at which the tagged resource is available. Additional queries can be made on this endpoint to fetch the resource's properties. |
label |
string |
This is a human-readable classifier representing the type of thing that is pointed to by the href. |
svm |
If the tagged resource belongs to an SVM, this property will be set. If the resource does not belong to an SVM (i.e. it belongs to the cluster as a whole), then this property will be empty and unreturned. |
value |
string |
The text value of the tag formatted as |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
