REST API reference
Retrieve resources for a tag
Retrieves resources associated with a specific tag to manage or organize your tagged items effectively.
HTTP method and endpoint
GET /resource-tags/{resource_tag.value}/resources
Introduced in
ONTAP 9.13
Usage notes
Retrieves the resources for a specific tag
resource_tag.value
string
path
True
  • format: key:value
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
label
string
query
False
Filter by label
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
return_records
boolean
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[resource_tag_resource]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "label": "volume",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
If the tagged resource belongs to an SVM, this property will be set. If the resource does not belong to an SVM (i.e. it belongs to the cluster as a whole), then this property will be empty and unreturned.
_links
_links
name
string
The name of the SVM.
uuid
string
This object provides a pointer to the tagged resource in the API. Details about the tagged object are available by querying the address of the href property.
label
string
This is a human-readable classifier representing the type of thing that is pointed to by the href.
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
