REST API reference
Retrieve the resources for a tag
GET /resource-tags/{resource_tag.value}/resources
Introduced In: 9.13
Retrieves the resources for a specific tag
resource_tag.value
string
path
True
  • format: key:value
value
string
query
False
Filter by value
  • Introduced in: 9.16
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
string
query
False
Filter by href
label
string
query
False
Filter by label
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
return_records
boolean
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[resource_tag_resource]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "href": "string",
      "label": "volume",
      "svm": {
        "name": "svm1",
      "value": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
If the tagged resource belongs to an SVM, this property will be set. If the resource does not belong to an SVM (i.e. it belongs to the cluster as a whole), then this property will be empty and unreturned.
_links
_links
name
string
uuid
string
This object provides a pointer to the tagged resource in the API. Details about the tagged object are available by querying the address of the href property.
string
This property provides the address in the API at which the tagged resource is available. Additional queries can be made on this endpoint to fetch the resource's properties.
label
string
This is a human-readable classifier representing the type of thing that is pointed to by the href.
svm
svm
value
string
The text value of the tag formatted as key:value.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
