Retrieve the anti-ransomware version of the nodes in the cluster
Retrieves the anti-ransomware version of nodes in the cluster to monitor and manage security features effectively.
HTTP method and endpoint
GET /security/anti-ransomware
Introduced in
ONTAP 9.16
Related ONTAP commands
security anti-ransomware show
fields |
array[string] |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
nodes |
array[anti_ransomware_node] |
uri |
string |
URI of the anti-ransomware package through a server |
"nodes": [
"name": "node1",
"version": "1.0"
"uri": "http://server/package"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
name |
string |
Name of the node. |
version |
string |
Anti-ransomware version. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
