Retrieve AKVs configured for all clusters and SVMs
Retrieves Azure Key Vaults (AKVs) configured for all clusters and SVMs to review encryption settings across your environment.
HTTP method and endpoint
GET /security/azure-key-vaults
Introduced in
ONTAP 9.8
Usage notes
Retrieves AKVs configured for all clusters and SVMs.
Related ONTAP commands
security key-manager external azure show -
security key-manager external azure check
scope |
string |
query |
False |
Filter by scope |
enabled |
boolean |
query |
False |
Filter by enabled
proxy_port |
integer |
query |
False |
Filter by proxy_port |
key_id |
string |
query |
False |
Filter by key_id |
vault_host |
string |
query |
False |
Filter by vault_host
proxy_type |
string |
query |
False |
Filter by proxy_type |
verify_ip |
boolean |
query |
False |
Filter by verify_ip
name |
string |
query |
False |
Filter by name |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
oauth_host |
string |
query |
False |
Filter by oauth_host
uuid |
string |
query |
False |
Filter by uuid |
port |
integer |
query |
False |
Filter by port
azure_reachability.message |
string |
query |
False |
Filter by azure_reachability.message |
azure_reachability.code |
string |
query |
False |
Filter by azure_reachability.code |
azure_reachability.reachable |
boolean |
query |
False |
Filter by azure_reachability.reachable |
proxy_username |
string |
query |
False |
Filter by proxy_username |
ekmip_reachability.reachable |
boolean |
query |
False |
Filter by ekmip_reachability.reachable |
ekmip_reachability.code |
string |
query |
False |
Filter by ekmip_reachability.code |
ekmip_reachability.node.uuid |
string |
query |
False |
Filter by ekmip_reachability.node.uuid |
ekmip_reachability.node.name |
string |
query |
False |
Filter by ekmip_reachability.node.name |
ekmip_reachability.message |
string |
query |
False |
Filter by ekmip_reachability.message |
state.message |
string |
query |
False |
Filter by state.message |
state.code |
string |
query |
False |
Filter by state.code |
state.available |
boolean |
query |
False |
Filter by state.available |
authentication_method |
string |
query |
False |
Filter by authentication_method
configuration.uuid |
string |
query |
False |
Filter by configuration.uuid
configuration.name |
string |
query |
False |
Filter by configuration.name
client_id |
string |
query |
False |
Filter by client_id |
verify_host |
boolean |
query |
False |
Filter by verify_host
tenant_id |
string |
query |
False |
Filter by tenant_id |
skip_verification |
boolean |
query |
False |
Filter by skip_verification
proxy_host |
string |
query |
False |
Filter by proxy_host |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[azure_key_vault] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"authentication_method": "client_secret",
"azure_reachability": {
"code": "346758",
"message": "AKV service is not reachable from all nodes - reason."
"client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
"configuration": {
"name": "default",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
"ekmip_reachability": [
"code": "346758",
"message": "embedded KMIP server status unavailable on node.",
"node": {
"name": "node1",
"key_id": "https://keyvault1.vault.azure.net/keys/key1/12345678901234567890123456789012",
"name": "https://kmip-akv-keyvault.vault.azure.net/",
"oauth_host": "login.microsoftonline.com",
"port": 443,
"proxy_host": "proxy.eng.com",
"proxy_port": 1234,
"proxy_type": "http",
"proxy_username": "proxyuser",
"scope": "string",
"skip_verification": "",
"state": {
"code": "346758",
"message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
"svm": {
"name": "svm1",
"tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"vault_host": "vault.azure.net",
"verify_host": "",
"verify_ip": ""
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537549 |
The Azure Key Vault Key Management Service is unreachable from one or more nodes. |
65537551 |
Top-level internal key protection key (KEK) unavailable on one or more nodes. |
65537552 |
Embedded KMIP server status not available. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
azure_reachability
Indicates whether or not the AKV service is reachable from all the nodes in the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code |
string |
Code corresponding to the status message. Returns a 0 if AKV service is reachable from all nodes in the cluster. |
message |
string |
Error message set when reachability is false. |
reachable |
boolean |
Set to true when the AKV service is reachable from all nodes of the cluster. |
configuration
Security keystore object reference.
_links |
name |
string |
Name of the configuration. |
uuid |
string |
Keystore UUID. |
node
_links |
name |
string |
uuid |
string |
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster.
code |
string |
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster. |
message |
string |
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false. |
node |
reachable |
boolean |
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster. |
state
Indicates whether or not the AKV wrapped internal key is available cluster wide.
available |
boolean |
Set to true when an AKV wrapped internal key is present on all nodes of the cluster. |
code |
string |
Code corresponding to the status message. Returns a 0 if AKV wrapped key is available on all nodes in the cluster. |
message |
string |
Error message set when top-level internal key protection key (KEK) availability on cluster is false. |
svm
_links |
name |
string |
uuid |
string |
azure_key_vault
_links |
string |
Authentication method for the AKV instance. |
azure_reachability |
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
client_id |
string |
Application client ID of the deployed Azure application with appropriate access to an AKV. |
configuration |
Security keystore object reference. |
ekmip_reachability |
array[ekmip_reachability] |
enabled |
boolean |
Indicates whether the configuration is enabled. |
key_id |
string |
Key Identifier of AKV key encryption key. |
name |
string |
Name of the deployed AKV that will be used by ONTAP for storing keys.
oauth_host |
string |
Open authorization server host name. |
port |
integer |
Authorization server and vault port number. |
proxy_host |
string |
Proxy host. |
proxy_port |
integer |
Proxy port. |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
skip_verification |
boolean |
Set to true to skip the verification of the updated user credentials when updating credentials. The default value is false. |
state |
svm |
tenant_id |
string |
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV. |
uuid |
string |
A unique identifier for the Azure Key Vault (AKV). |
vault_host |
string |
AKV host subdomain. |
verify_host |
boolean |
Verify the identity of the AKV host name. |
verify_ip |
boolean |
Verify the identity of the AKV IP address. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
