Retrieve AKVs configured for all clusters and SVMs
Retrieves the Azure Key Vaults (AKVs) configured for all clusters and Storage Virtual Machines (SVMs) to access the necessary encryption keys for securing your data.
HTTP method and endpoint
GET /security/azure-key-vaults
Introduced in
ONTAP 9.8
Usage notes
Retrieves AKVs configured for all clusters and SVMs. Note: This method is only available to the Azure NetApp Files Cloud Volume Services.
Related ONTAP commands
security key-manager external azure show -
security key-manager external azure check
state.code |
integer |
query |
False |
Filter by state.code |
state.available |
boolean |
query |
False |
Filter by state.available |
state.message |
string |
query |
False |
Filter by state.message |
scope |
string |
query |
False |
Filter by scope |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
ekmip_reachability.node.name |
string |
query |
False |
Filter by ekmip_reachability.node.name |
ekmip_reachability.node.uuid |
string |
query |
False |
Filter by ekmip_reachability.node.uuid |
ekmip_reachability.reachable |
boolean |
query |
False |
Filter by ekmip_reachability.reachable |
ekmip_reachability.message |
string |
query |
False |
Filter by ekmip_reachability.message |
ekmip_reachability.code |
integer |
query |
False |
Filter by ekmip_reachability.code |
proxy_port |
integer |
query |
False |
Filter by proxy_port |
uuid |
string |
query |
False |
Filter by uuid |
proxy_username |
string |
query |
False |
Filter by proxy_username |
proxy_type |
string |
query |
False |
Filter by proxy_type |
name |
string |
query |
False |
Filter by name |
client_id |
string |
query |
False |
Filter by client_id |
azure_reachability.message |
string |
query |
False |
Filter by azure_reachability.message |
azure_reachability.reachable |
boolean |
query |
False |
Filter by azure_reachability.reachable |
azure_reachability.code |
integer |
query |
False |
Filter by azure_reachability.code |
proxy_host |
string |
query |
False |
Filter by proxy_host |
key_id |
string |
query |
False |
Filter by key_id |
tenant_id |
string |
query |
False |
Filter by tenant_id |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[azure_key_vault] |
"next": {
"href": "/api/resourcelink"
"records": [
"azure_reachability": {
"code": "346758",
"message": "AKV service is not reachable from all nodes - reason."
"client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
"ekmip_reachability": [
"code": "346758",
"message": "embedded KMIP server status unavailable on node.",
"node": {
"name": "node1",
"key_id": "https://keyvault1.vault.azure.net/keys/key1",
"name": "https://kmip-akv-keyvault.vault.azure.net/",
"proxy_host": "proxy.eng.com",
"proxy_port": "1234",
"proxy_type": "http",
"proxy_username": "proxyuser",
"scope": "string",
"state": {
"code": "346758",
"message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
"svm": {
"name": "svm1",
"tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
azure_reachability
Indicates whether or not the AKV service is reachable from all the nodes in the cluster.
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code |
integer |
Code corresponding to the status message. Returns a 0 if AKV service is reachable from all nodes in the cluster. |
message |
string |
Error message set when reachability is false. |
reachable |
boolean |
Set to true when the AKV service is reachable from all nodes of the cluster. |
node
_links |
name |
string |
uuid |
string |
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster.
code |
integer |
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster. |
message |
string |
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false. |
node |
reachable |
boolean |
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster. |
state
Indicates whether or not the AKV wrapped internal key is available cluster wide.
available |
boolean |
Set to true when an AKV wrapped internal key is present on all nodes of the cluster. |
code |
integer |
Code corresponding to the status message. Returns a 0 if AKV wrapped key is available on all nodes in the cluster. |
message |
string |
Error message set when top-level internal key protection key (KEK) availability on cluster is false. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
azure_key_vault
_links |
azure_reachability |
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
client_id |
string |
Application client ID of the deployed Azure application with appropriate access to an AKV. |
ekmip_reachability |
array[ekmip_reachability] |
key_id |
string |
Key Identifier of AKV key encryption key. |
name |
string |
Name of the deployed AKV that is used by the Azure NetApp Files Cloud Volume Services for storing keys. |
proxy_host |
string |
Proxy host. |
proxy_port |
integer |
Proxy port. |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
state |
svm |
tenant_id |
string |
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV. |
uuid |
string |
A unique identifier for the Azure Key Vault (AKV). |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
