Retrieve a group-to-role mapping entry
GET /security/group/role-mappings/{group_id}/{ontap_role.name}
Introduced In: 9.16
Retrieves a group to role mapping entry.
Related ONTAP commands
security login group role-mapping show
group_id  |
integer  |
path  |
True  |
Group ID.
ontap_role.name  |
string  |
path  |
True  |
Role name.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
comment  |
string  |
Any comment regarding this group entry.  |
group_id  |
integer  |
Group ID.  |
ontap_role  |
Role name.  |
scope  |
string  |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.  |
    "next": {
      "href": "/api/resourcelink"
  "comment": "string",
  "group_id": 1,
  "ontap_role": {
    "name": "admin"
  "scope": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
ontap_role
Role name.
_links  |
name  |
string  |
Role name  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
