REST API reference
Retrieve all group-to-role mapping entries
Retrieves all group-to-role mapping entries to review the current associations between groups and their roles in the system. This helps ensure that access permissions are correctly configured according to organizational policies.
HTTP method and endpoint
GET /security/group/role-mappings
Introduced in
ONTAP 9.16
Usage notes
Retrieves all the group to role mapping entries.
  • security login group role-mapping show
scope
string
query
False
Filter by scope
group_id
integer
query
False
Filter by group_id
  • Max value: 4294967295
  • Min value: 1
ontap_role.name
string
query
False
Filter by ontap_role.name
comment
string
query
False
Filter by comment
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[group_role_mappings]
    "next": {
      "href": "/api/resourcelink"
  "records": [
        "next": {
      "comment": "string",
      "group_id": 1,
      "ontap_role": {
        "name": "admin"
      "scope": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ontap_role
Role name.
_links
_links
name
string
Role name
group_role_mappings
_links
_links
comment
string
Any comment regarding this group entry.
group_id
integer
Group ID.
ontap_role
ontap_role
Role name.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
