Retrieve all group-to-role mapping entries
Retrieves all group-to-role mapping entries, which helps you understand the role assignments for different groups.
HTTP method and endpoint
GET /security/group/role-mappings
Introduced in
ONTAP 9.16
Usage notes
Retrieves all the group to role mapping entries.
Related ONTAP commands
security login group role-mapping show
ontap_role.name |
string |
query |
False |
Filter by ontap_role.name |
comment |
string |
query |
False |
Filter by comment |
group_id |
integer |
query |
False |
Filter by group_id
scope |
string |
query |
False |
Filter by scope |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[group_role_mappings] |
"next": {
"href": "/api/resourcelink"
"records": [
"next": {
"comment": "string",
"group_id": 1,
"ontap_role": {
"name": "admin"
"scope": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ontap_role
Role name.
_links |
name |
string |
Role name |
group_role_mappings
_links |
comment |
string |
Any comment regarding this group entry. |
group_id |
integer |
Group ID. |
ontap_role |
Role name. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
