Retrieve all group entries
Retrieves all group entries to review the configured login groups within your ONTAP environment.
HTTP method and endpoint
GET /security/groups
Introduced in
ONTAP 9.16
Related ONTAP commands
security login group show
owner.name |
string |
query |
False |
Filter by owner.name |
owner.uuid |
string |
query |
False |
Filter by owner.uuid |
comment |
string |
query |
False |
Filter by comment |
name |
string |
query |
False |
Filter by name |
uuid |
string |
query |
False |
Filter by uuid |
type |
string |
query |
False |
Filter by type |
id |
integer |
query |
False |
Filter by id |
scope |
string |
query |
False |
Filter by scope |
create_time |
string |
query |
False |
Filter by create_time |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[security_group] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"comment": "Azure Group",
"create_time": "string",
"id": 0,
"name": "AzureGroup1",
"owner": {
"name": "svm1",
"scope": "string",
"type": "entra",
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
_links
self |
owner
Group owner. Used to identify a cluster or an SVM.
_links |
name |
string |
uuid |
string |
security_group
_links |
comment |
string |
Any comment regarding this group entry. |
create_time |
string |
Date and time indicating when this group entry was created. |
id |
integer |
Group ID which is unique per group across the system. It is a read-only field and it automatically assigns the next available unique number. |
name |
string |
Group name. |
owner |
Group owner. Used to identify a cluster or an SVM. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
type |
string |
Group type. |
uuid |
string |
Group UUID from external Active Directory. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
