Retrieve a WebAuthn global setting entry
Retrieves a WebAuthn global setting entry to access the configuration details for WebAuthn authentication settings. This can be useful for reviewing or auditing authentication settings in your environment.
HTTP method and endpoint
GET /security/webauthn/global-settings/{owner.uuid}
Introduced in
ONTAP 9.16
Related ONTAP commands
security webauthn show
owner.uuid |
string |
path |
True |
Used to identify a cluster or an SVM. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
attestation |
string |
Attestation conveyance type. |
owner |
require_rk |
boolean |
Specifies whether the resident key is required. |
resident_key |
string |
Resident key. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
timeout |
integer |
The timeout interval for the WebAuthn request, in milliseconds. |
user_verification |
string |
User verification. |
"href": "/api/resourcelink"
"attestation": "none",
"owner": {
"name": "svm1",
"require_rk": "",
"resident_key": "discouraged",
"scope": "string",
"timeout": 600000,
"user_verification": "discouraged"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
_links
self |
svm_reference
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
