Retrieve WebAuthn global settings for a cluster and all SVMs
Retrieves WebAuthn global settings for a cluster and all SVMs to review the authentication configurations deployed across your network.
HTTP method and endpoint
GET /security/webauthn/global-settings
Introduced in
ONTAP 9.16
Usage notes
Retrieve WebAuthn global settings for a cluster and all SVMs.
Related ONTAP commands
security webauthn show
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[webauthn_global] |
"next": {
"href": "/api/resourcelink"
"records": [
"attestation": "none",
"owner": {
"name": "svm1",
"require_rk": "",
"resident_key": "discouraged",
"scope": "string",
"timeout": 600000,
"user_verification": "discouraged"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
_links
self |
svm_reference
_links |
name |
string |
uuid |
string |
webauthn_global
WebAuthn global settings.
_links |
attestation |
string |
Attestation conveyance type. |
owner |
require_rk |
boolean |
Specifies whether the resident key is required. |
resident_key |
string |
Resident key. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
timeout |
integer |
The timeout interval for the WebAuthn request, in milliseconds. |
user_verification |
string |
User verification. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
