REST API reference
Retrieve WebAuthn global settings for a cluster and all SVMs
Retrieves WebAuthn global settings for a cluster and all SVMs to review the authentication configurations deployed across your network.
HTTP method and endpoint
GET /security/webauthn/global-settings
Introduced in
ONTAP 9.16
Usage notes
Retrieve WebAuthn global settings for a cluster and all SVMs.
  • security webauthn show
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records.
records
array[webauthn_global]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "attestation": "none",
      "owner": {
        "name": "svm1",
      "require_rk": "",
      "resident_key": "discouraged",
      "scope": "string",
      "timeout": 600000,
      "user_verification": "discouraged"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
svm_reference
_links
_links
name
string
uuid
string
webauthn_global
WebAuthn global settings.
_links
self_link
attestation
string
Attestation conveyance type.
owner
svm_reference
require_rk
boolean
Specifies whether the resident key is required.
resident_key
string
Resident key.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
timeout
integer
The timeout interval for the WebAuthn request, in milliseconds.
user_verification
string
User verification.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
