REST API reference
Retrieve a WebAuthn supported algorithms entry
Retrieves an entry for supported WebAuthn algorithms, gaining insight into the authentication algorithms available for use.
HTTP method and endpoint
GET /security/webauthn/supported-algorithms/{owner.uuid}/{algorithm.name}
Introduced in
ONTAP 9.16
Usage notes
Retrieves a WebAuthn supported algorithms entry.
  • security webauthn supported-algorithms show
owner.uuid
string
path
True
Used to identify a cluster or an SVM.
algorithm.name
string
path
True
Algorithm name.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
algorithm
algorithm
owner
svm_reference
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
      "href": "/api/resourcelink"
  "algorithm": {
    "id": -7,
    "name": "ES-256",
    "type": "string"
  "owner": {
    "name": "svm1",
  "scope": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
algorithm
id
integer
Algorithm ID.
name
string
Algorithm name.
type
string
Algorithm type.
self
svm_reference
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
