Retrieve a WebAuthn supported algorithms entry
Retrieves an entry for supported WebAuthn algorithms, gaining insight into the authentication algorithms available for use.
HTTP method and endpoint
GET /security/webauthn/supported-algorithms/{owner.uuid}/{algorithm.name}
Introduced in
ONTAP 9.16
Usage notes
Retrieves a WebAuthn supported algorithms entry.
Related ONTAP commands
security webauthn supported-algorithms show
owner.uuid |
string |
path |
True |
Used to identify a cluster or an SVM. |
algorithm.name |
string |
path |
True |
Algorithm name. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
algorithm |
owner |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
"href": "/api/resourcelink"
"algorithm": {
"id": -7,
"name": "ES-256",
"type": "string"
"owner": {
"name": "svm1",
"scope": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
algorithm
id |
integer |
Algorithm ID. |
name |
string |
Algorithm name. |
type |
string |
Algorithm type. |
_links
self |
svm_reference
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
