Retrieve QoS workloads
GET /storage/qos/workloads
Introduced In: 9.10
Retrieves a collection of QoS workloads.
volume |
string |
query |
False |
Filter by volume |
name |
string |
query |
False |
Filter by name |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
file |
string |
query |
False |
Filter by file |
uuid |
string |
query |
False |
Filter by uuid |
wid |
integer |
query |
False |
Filter by wid |
workload_class |
string |
query |
False |
Filter by workload_class |
qtree |
string |
query |
False |
Filter by qtree |
policy.uuid |
string |
query |
False |
Filter by policy.uuid |
policy.name |
string |
query |
False |
Filter by policy.name |
lun |
string |
query |
False |
Filter by lun |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
error |
num_records |
integer |
Number of records |
records |
array[qos_workload] |
"next": {
"href": "/api/resourcelink"
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"message": "entry doesn't exist"
"num_records": 1,
"records": [
"file": "string",
"lun": "string",
"name": "volume1-wid123",
"policy": {
"name": "performance",
"qtree": "string",
"svm": {
"name": "svm1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"volume": "volume1",
"wid": 123,
"workload_class": "autovolume"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
_links
self |
policy
QoS policy group reference.
_links |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
svm
_links |
name |
string |
uuid |
string |
qos_workload
_links |
file |
string |
Name of the file. |
lun |
string |
Name of the LUN. The name of the LUN will be displayed as "(unknown)" if the name cannot be retrieved. |
name |
string |
Name of the QoS workload. |
policy |
QoS policy group reference. |
qtree |
string |
Name of the Qtree. |
svm |
uuid |
string |
volume |
string |
Name of the volume. The name of the volume will be displayed as "(unknown)" if the name cannot be retrieved. |
wid |
integer |
Workload ID of the QoS workload. |
workload_class |
string |
Class of the QoS workload. |
returned_error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
