REST API reference
Retrieve QoS workloads
Retrieves a collection of QoS workloads to examine their configurations and performance metrics.
HTTP method and endpoint
GET /storage/qos/workloads
Introduced in
ONTAP 9.10
uuid
string
query
False
Filter by uuid
qtree
string
query
False
Filter by qtree
name
string
query
False
Filter by name
workload_class
string
query
False
Filter by workload_class
lun
string
query
False
Filter by lun
volume
string
query
False
Filter by volume
policy.uuid
string
query
False
Filter by policy.uuid
policy.name
string
query
False
Filter by policy.name
file
string
query
False
Filter by file
wid
integer
query
False
Filter by wid
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
error
error
num_records
integer
Number of records
records
array[qos_workload]
    "next": {
      "href": "/api/resourcelink"
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "message": "entry doesn't exist"
  "num_records": 1,
  "records": [
      "file": "string",
      "lun": "string",
      "name": "volume1-wid123",
      "policy": {
        "name": "performance",
      "qtree": "string",
      "svm": {
        "name": "svm1",
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "volume": "volume1",
      "wid": 123,
      "workload_class": "autovolume"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
self
policy
QoS policy group reference.
_links
_links
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
svm
_links
_links
name
string
uuid
string
qos_workload
_links
_links
file
string
Name of the file.
lun
string
Name of the LUN. The name of the LUN will be displayed as "(unknown)" if the name cannot be retrieved.
name
string
Name of the QoS workload.
policy
policy
qtree
string
Name of the Qtree.
svm
svm
uuid
string
volume
string
Name of the volume. The name of the volume will be displayed as "(unknown)" if the name cannot be retrieved.
wid
integer
Workload ID of the QoS workload.
workload_class
string
Class of the QoS workload.
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
