Retrieve the quota report records for all FlexVol and FlexGroup volumes
Retrieves quota report records for all FlexVol and FlexGroup volumes to review storage capacity and usage limits across your environment.
HTTP method and endpoint
GET /storage/quota/reports
Introduced in
ONTAP 9.6
Usage notes
Retrieves the quota report records for all FlexVol volumes and FlexGroup volumes.
Related ONTAP commands
quota report
space.hard_limit |
integer |
query |
False |
Filter by space.hard_limit |
space.used.hard_limit_percent |
integer |
query |
False |
Filter by space.used.hard_limit_percent |
space.used.soft_limit_percent |
integer |
query |
False |
Filter by space.used.soft_limit_percent |
space.used.total |
integer |
query |
False |
Filter by space.used.total |
space.soft_limit |
integer |
query |
False |
Filter by space.soft_limit |
type |
string |
query |
False |
Filter by type |
qtree.name |
string |
query |
False |
Filter by qtree.name |
qtree.id |
integer |
query |
False |
Filter by qtree.id |
volume.uuid |
string |
query |
False |
Filter by volume.uuid |
volume.name |
string |
query |
False |
Filter by volume.name |
files.hard_limit |
integer |
query |
False |
Filter by files.hard_limit |
files.used.hard_limit_percent |
integer |
query |
False |
Filter by files.used.hard_limit_percent |
files.used.soft_limit_percent |
integer |
query |
False |
Filter by files.used.soft_limit_percent |
files.used.total |
integer |
query |
False |
Filter by files.used.total |
files.soft_limit |
integer |
query |
False |
Filter by files.soft_limit |
group.id |
string |
query |
False |
Filter by group.id |
group.name |
string |
query |
False |
Filter by group.name |
index |
integer |
query |
False |
Filter by index |
users.id |
string |
query |
False |
Filter by users.id |
users.name |
string |
query |
False |
Filter by users.name |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
show_default_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, the default records are not reported.
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[quota_report] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"files": {
"hard_limit": 0,
"soft_limit": 0,
"used": {
"hard_limit_percent": 0,
"soft_limit_percent": 0,
"total": 0
"group": {
"id": "string",
"name": "string"
"index": 0,
"qtree": {
"id": 1,
"name": "qt1"
"space": {
"hard_limit": 0,
"soft_limit": 0,
"used": {
"total": 0
"svm": {
"name": "svm1",
"type": "string",
"users": [
"id": "string",
"name": "string"
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
used
integer |
Total files used as a percentage of file hard limit |
integer |
Total files used as a percentage of file soft limit |
total |
integer |
Total files used |
files
hard_limit |
integer |
File hard limit |
soft_limit |
integer |
File soft limit |
used |
group
This parameter specifies the target group associated with the given quota report record. This parameter is available for group quota records and is not available for user or tree quota records. The target group is identified by a UNIX group name and UNIX group identifier.
id |
string |
Quota target group ID |
name |
string |
Quota target group name |
qtree
This parameter specifies the target qtree associated with the user, group, or tree record. For a user/group quota policy rule at volume level, this parameter is not valid. For a default tree quota policy rule, this parameter is specified as "" or "*". For a tree quota policy rule at qtree level, this parameter specifies a qtree name and a qtree identifier.
_links |
id |
integer |
The unique identifier for a qtree. |
name |
string |
The name of the qtree. |
used
integer |
Total space used as a percentage of space hard limit |
integer |
Total space used as a percentage of space soft limit |
total |
integer |
Total space used |
space
hard_limit |
integer |
Space hard limit in bytes |
soft_limit |
integer |
Space soft limit in bytes |
used |
svm
_links |
name |
string |
uuid |
string |
users
id |
string |
Quota target user ID |
name |
string |
Quota target user name |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
quota_report
_links |
files |
group |
This parameter specifies the target group associated with the given quota report record. This parameter is available for group quota records and is not available for user or tree quota records. The target group is identified by a UNIX group name and UNIX group identifier. |
index |
integer |
Index that identifies a unique quota record. Valid in URL. |
qtree |
This parameter specifies the target qtree associated with the user, group, or tree record. For a user/group quota policy rule at volume level, this parameter is not valid. For a default tree quota policy rule, this parameter is specified as "" or "*". For a tree quota policy rule at qtree level, this parameter specifies a qtree name and a qtree identifier. |
space |
svm |
type |
string |
Quota type associated with the quota record. |
users |
array[users] |
This parameter specifies the target user or users associated with the given quota report record. This parameter is available for user quota records and is not available for group or tree quota records. The target user or users are identified by a user name and user identifier. The user name can be a UNIX user name or a Windows user name, and the identifier can be a UNIX user identifier or a Windows security identifier. |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
