REST API reference
Retrieve the quota report records for all FlexVol and FlexGroup volumes
GET /storage/quota/reports
Introduced In: 9.6
Retrieves the quota report records for all FlexVol volumes and FlexGroup volumes.
  • quota report
space.soft_limit
integer
query
False
Filter by space.soft_limit
space.used.soft_limit_percent
integer
query
False
Filter by space.used.soft_limit_percent
space.used.total
integer
query
False
Filter by space.used.total
space.used.hard_limit_percent
integer
query
False
Filter by space.used.hard_limit_percent
space.hard_limit
integer
query
False
Filter by space.hard_limit
index
integer
query
False
Filter by index
files.soft_limit
integer
query
False
Filter by files.soft_limit
files.hard_limit
integer
query
False
Filter by files.hard_limit
files.used.total
integer
query
False
Filter by files.used.total
files.used.hard_limit_percent
integer
query
False
Filter by files.used.hard_limit_percent
files.used.soft_limit_percent
integer
query
False
Filter by files.used.soft_limit_percent
volume.name
string
query
False
Filter by volume.name
volume.uuid
string
query
False
Filter by volume.uuid
qtree.id
integer
query
False
Filter by qtree.id
qtree.name
string
query
False
Filter by qtree.name
users.id
string
query
False
Filter by users.id
users.name
string
query
False
Filter by users.name
type
string
query
False
Filter by type
group.id
string
query
False
Filter by group.id
group.name
string
query
False
Filter by group.name
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
show_default_records
boolean
query
False
The default is true for GET calls. When set to false, the default records are not reported.
  • Introduced in: 9.7
  • Default value: 1
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[quota_report]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "files": {
        "hard_limit": 0,
        "soft_limit": 0,
        "used": {
          "hard_limit_percent": 0,
          "soft_limit_percent": 0,
          "total": 0
      "group": {
        "id": "string",
        "name": "string"
      "index": 0,
      "qtree": {
        "id": 1,
        "name": "qt1"
      "space": {
        "hard_limit": 0,
        "soft_limit": 0,
        "used": {
          "total": 0
      "svm": {
        "name": "svm1",
      "type": "string",
      "users": [
          "id": "string",
          "name": "string"
      "volume": {
        "name": "volume1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
used
hard_limit_percent
integer
Total files used as a percentage of file hard limit
soft_limit_percent
integer
Total files used as a percentage of file soft limit
total
integer
Total files used
files
hard_limit
integer
File hard limit
soft_limit
integer
File soft limit
used
used
group
This parameter specifies the target group associated with the given quota report record. This parameter is available for group quota records and is not available for user or tree quota records. The target group is identified by a UNIX group name and UNIX group identifier.
id
string
Quota target group ID
name
string
Quota target group name
qtree
This parameter specifies the target qtree associated with the user, group, or tree record. For a user/group quota policy rule at volume level, this parameter is not valid. For a default tree quota policy rule, this parameter is specified as "" or "*". For a tree quota policy rule at qtree level, this parameter specifies a qtree name and a qtree identifier.
_links
_links
id
integer
The unique identifier for a qtree.
name
string
The name of the qtree.
used
hard_limit_percent
integer
Total space used as a percentage of space hard limit
soft_limit_percent
integer
Total space used as a percentage of space soft limit
total
integer
Total space used
space
hard_limit
integer
Space hard limit in bytes
soft_limit
integer
Space soft limit in bytes
used
used
svm
_links
_links
name
string
uuid
string
users
id
string
Quota target user ID
name
string
Quota target user name
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
quota_report
_links
_links
files
files
group
group
index
integer
Index that identifies a unique quota record. Valid in URL.
qtree
qtree
space
space
svm
svm
type
string
Quota type associated with the quota record.
users
array[users]
This parameter specifies the target user or users associated with the given quota report record. This parameter is available for user quota records and is not available for group or tree quota records. The target user or users are identified by a user name and user identifier. The user name can be a UNIX user name or a Windows user name, and the identifier can be a UNIX user identifier or a Windows security identifier.
volume
volume
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
