Retrieve the file fingerprint information for a specific session ID
GET /storage/snaplock/file-fingerprints/{id}
Introduced In: 9.7
Retrieves the file fingerprint information for a specific session ID.
Related ONTAP commands
volume file fingerprint dump
Learn more
id  |
string  |
path  |
True  |
Unique identifier of the operation  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
algorithm  |
string  |
The digest algorithm which is used for the fingerprint computation  |
data_fingerprint  |
string  |
The digest value of data of the file. The fingerprint is base64 encoded. This field is not included if the scope is metadata-only.  |
file_size  |
integer  |
The size of the file in bytes.  |
file_type  |
string  |
The type of the file.  |
id  |
integer  |
A unique identifier for the fingerprint operation  |
metadata_fingerprint  |
string  |
The digest value of metadata of the file. The metadata fingerprint is calculated for file size, file ctime, file mtime, file crtime, file retention time, file uid, file gid, and file type. The fingerprint is base64 encoded. This field is not included if the scope is data-only.  |
path  |
string  |
Specifies the path on which file fingerprint operation is running or has completed. Specifies the path relative to the output volume root, of the form "/path". The path can be path to a file or a directory.  |
scope  |
string  |
The scope of the file which is used for the fingerprint computation  |
state  |
string  |
Specifies the status of fingerprint operation.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
volume  |
      "href": "/api/resourcelink"
  "algorithm": "sha256",
  "data_fingerprint": "MOFJVevxNSJm3C/4Bn5oEEYH51CrudOzZYK4r5Cfy1g=",
  "file_size": 1048576,
  "file_type": "worm",
  "id": 17039367,
  "metadata_fingerprint": "8iMjqJXiNcqgXT5XuRhLiEwIrJEihDmwS0hrexnjgmc=",
  "path": "/homedir/dir1",
  "scope": "data_only",
  "state": "completed",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090441  |
Invalid key values. Provide session ID or Vserver UUID and volume UUID  |
14090449  |
File fingerprint operation has not completed  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
volume
_links  |
name  |
string  |
The name of the volume. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
