REST API reference
Retrieve the file fingerprint information for a specific session ID
Retrieves file fingerprint information associated with a specific session ID. This is useful when you need to access detailed fingerprint data for file tracking or verification purposes.
HTTP method and endpoint
GET /storage/snaplock/file-fingerprints/{id}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the file fingerprint information for a specific session ID.
  • volume file fingerprint dump
id
string
path
True
Unique identifier of the operation
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
algorithm
string
The digest algorithm which is used for the fingerprint computation
data_fingerprint
string
The digest value of data of the file. The fingerprint is base64 encoded. This field is not included if the scope is metadata-only.
file_size
integer
The size of the file in bytes.
file_type
string
The type of the file.
id
integer
A unique identifier for the fingerprint operation
metadata_fingerprint
string
The digest value of metadata of the file. The metadata fingerprint is calculated for file size, file ctime, file mtime, file crtime, file retention time, file uid, file gid, and file type. The fingerprint is base64 encoded. This field is not included if the scope is data-only.
path
string
Specifies the path on which file fingerprint operation is running or has completed. Specifies the path relative to the output volume root, of the form "/path". The path can be path to a file or a directory.
scope
string
The scope of the file which is used for the fingerprint computation
state
string
Specifies the status of fingerprint operation.
svm
svm
volume
volume
      "href": "/api/resourcelink"
  "algorithm": "sha256",
  "data_fingerprint": "MOFJVevxNSJm3C/4Bn5oEEYH51CrudOzZYK4r5Cfy1g=",
  "file_size": 1048576,
  "file_type": "worm",
  "id": 17039367,
  "metadata_fingerprint": "8iMjqJXiNcqgXT5XuRhLiEwIrJEihDmwS0hrexnjgmc=",
  "path": "/homedir/dir1",
  "scope": "data_only",
  "state": "completed",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: Default
ONTAP Error Response codes
Error code Description
14090441
Invalid key values. Provide session ID or Vserver UUID and volume UUID
14090449
File fingerprint operation has not completed
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
