REST API reference
Retrieve volume efficiency policy details
Retrieves the details of a specific volume efficiency policy, helping you understand its current configuration and settings.
HTTP method and endpoint
GET /storage/volume-efficiency-policies/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the details of the specified volume efficiency policy.
  • volume efficiency policy show
uuid
string
path
True
Volume efficiency policy UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
comment
string
A comment associated with the volume efficiency policy.
duration
integer
This field is used with the policy type "scheduled" to indicate the allowed duration for a session, in hours. Possible value is a number between 0 and 999 inclusive. Default is unlimited indicated by value 0.
enabled
boolean
Is the volume efficiency policy enabled?
name
string
Name of the volume efficiency policy.
qos_policy
string
QoS policy for the sis operation. Possible values are background and best_effort. In background, sis operation will run in background with minimal or no impact on data serving client operations. In best_effort, sis operations may have some impact on data serving client operations.
schedule
schedule
start_threshold_percent
integer
This field is used with the policy type "threshold" to indicate the threshold percentage for triggering the volume efficiency policy. It is mutually exclusive of the schedule.
svm
svm
type
string
Type of volume efficiency policy.
uuid
string
Unique identifier of volume efficiency policy.
      "href": "/api/resourcelink"
  "comment": "string",
  "name": "string",
  "qos_policy": "string",
  "schedule": {
    "name": "string"
  "svm": {
    "name": "svm1",
  "type": "string",
  "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
schedule
name
string
Schedule at which volume efficiency policies are captured on the SVM. Some common schedules already defined in the system are hourly, daily, weekly, at 5 minute intervals, and at 8 hour intervals. Volume efficiency policies with custom schedules can be referenced.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
