Retrieve volume efficiency policy details
Retrieves the details of a specific volume efficiency policy, helping you understand its current configuration and settings.
HTTP method and endpoint
GET /storage/volume-efficiency-policies/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the details of the specified volume efficiency policy.
Related ONTAP commands
volume efficiency policy show
Learn more
uuid |
string |
path |
True |
Volume efficiency policy UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
comment |
string |
A comment associated with the volume efficiency policy. |
duration |
integer |
This field is used with the policy types "scheduled" and "auto" to indicate the allowed duration for a session, in hours. Possible value is a number between 0 and 999 inclusive. Default is unlimited indicated by value 0. |
enabled |
boolean |
Is the volume efficiency policy enabled? |
name |
string |
Name of the volume efficiency policy. |
qos_policy |
string |
QoS policy for the sis operation. Possible values are background and best_effort. In background, sis operation will run in background with minimal or no impact on data serving client operations. In best_effort, sis operations may have some impact on data serving client operations. |
schedule |
start_threshold_percent |
integer |
This field is used with the policy type "threshold" to indicate the threshold percentage for triggering the volume efficiency policy. It is mutuallly exclusive of the schedule. |
svm |
type |
string |
Type of volume efficiency policy. |
uuid |
string |
Unique identifier of volume efficiency policy. |
"href": "/api/resourcelink"
"comment": "string",
"duration": "5",
"enabled": 1,
"name": "default",
"qos_policy": "string",
"schedule": {
"name": "daily"
"start_threshold_percent": "30",
"svm": {
"name": "svm1",
"type": "string",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
schedule
name |
string |
Schedule at which volume efficiency policies are captured on the SVM. Some common schedules already defined in the system are hourly, daily, weekly, at 5 minute intervals, and at 8 hour intervals. Volume efficiency policies with custom schedules can be referenced. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
