Retrieve files with the most I/O activity
GET /storage/volumes/{volume.uuid}/top-metrics/files
Introduced In: 9.10
Retrieves a list of files with the most I/O activity.
Platform Specifics
Unified ONTAP: GET must be used to retrieve a list of files with the most I/O activity.
volume.uuid  |
string  |
path  |
True  |
Volume UUID  |
top_metric  |
string  |
query  |
False  |
I/O activity type
max_records_per_volume  |
integer  |
query  |
False  |
Max records per volume.  |
svm.name  |
string  |
query  |
False  |
Filter by svm.name  |
svm.uuid  |
string  |
query  |
False  |
Filter by svm.uuid  |
throughput.write  |
integer  |
query  |
False  |
Filter by throughput.write  |
throughput.error.upper_bound  |
integer  |
query  |
False  |
Filter by throughput.error.upper_bound  |
throughput.error.lower_bound  |
integer  |
query  |
False  |
Filter by throughput.error.lower_bound  |
throughput.read  |
integer  |
query  |
False  |
Filter by throughput.read  |
path  |
string  |
query  |
False  |
Filter by path  |
iops.error.upper_bound  |
integer  |
query  |
False  |
Filter by iops.error.upper_bound  |
iops.error.lower_bound  |
integer  |
query  |
False  |
Filter by iops.error.lower_bound  |
iops.read  |
integer  |
query  |
False  |
Filter by iops.read  |
iops.write  |
integer  |
query  |
False  |
Filter by iops.write  |
volume.name  |
string  |
query  |
False  |
Filter by volume.name  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_records  |
boolean  |
query  |
False  |
return_timeout  |
integer  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
incomplete_response_reason  |
Indicates that the metric report provides incomplete data.  |
notice  |
Optional field that indicates why no records are returned by the volume activity tracking REST API.  |
num_records  |
integer  |
Number of records.  |
records  |
array[top_metrics_file]  |
    "next": {
      "href": "/api/resourcelink"
  "incomplete_response_reason": {
    "code": "111411207",
    "message": "Partial data has been returned for this metric report. Reason: The activity tracking report for this volume is not available because the system is busy collecting tracking data."
  "notice": {
    "message": "No read/write traffic on volume."
  "num_records": 1,
  "records": [
        "metadata": {
      "iops": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 5,
        "write": 4
      "path": "/dir_abc/dir_123/file_1",
      "svm": {
        "name": "svm1",
      "throughput": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 2,
        "write": 20
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
124518405  |
Volume activity tracking is not supported on volumes that contain LUNs.  |
124518407  |
Volume activity tracking is not supported on FlexCache volumes.  |
124518408  |
Volume activity tracking is not supported on audit staging volumes.  |
124518409  |
Volume activity tracking is not supported on object store server volumes.  |
124518410  |
Volume activity tracking is not supported on SnapMirror destination volumes.  |
124518411  |
Enabling or disabling volume activity tracking is not supported on individual FlexGroup constituents.  |
124518412  |
Volume activity tracking is not supported on SnapLock volumes.  |
124518414  |
Volume activity tracking is not supported on volumes that contain NVMe namespaces.  |
124518415  |
Failed to get the volume activity tracking report on volume volume.name in SVM svm.name.  |
124518416  |
Internal error. Volume activity tracking report timed out for volume volume.name in SVM svm.name.  |
124518417  |
Volume wildcard queries are not supported for activity tracking reports.  |
124518418  |
The activity tracking report for volume volume.name in SVM svm.name returned zero records. Check whether the volume has read/write traffic. Refer to the REST API documentation for more information.  |
124518422  |
Volume activity tracking is not supported on All SAN Array clusters.  |
124519411  |
Volume activity tracking is not enabled on the volume.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
code  |
string  |
Warning code indicating why partial data was reported.  |
message  |
string  |
A message describing the reason for partial data.  |
notice
code  |
string  |
Warning code indicating why no records are returned.  |
message  |
string  |
Details why no records are returned.  |
_links
metadata  |
self  |
top_metric_value_error_bounds
lower_bound  |
integer  |
Lower bound of the nominal value of a metric.  |
upper_bound  |
integer  |
Upper bound of the nominal value of a metric.  |
iops
error  |
read  |
integer  |
Average number of read operations per second.  |
write  |
integer  |
Average number of write operations per second.  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
throughput
error  |
read  |
integer  |
Average number of read bytes received per second.  |
write  |
integer  |
Average number of write bytes received per second.  |
volume
_links  |
name  |
string  |
The name of the volume. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
top_metrics_file
Information about a file's IO activity.
_links  |
iops  |
path  |
string  |
Path of the file.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
throughput  |
volume  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
